Rear seat belts
bam bam
Rear seat belts
Post by bam bam »
Ok I am new to beetles and fell into owning a 66 beetle (I think I like it)I already have a bay . What I need to know is can I fit seat belts into the rear are there bolt holes in the roof lining etc to mount them............
CharlieC66
Post by CharlieC66 »
Yes, there are mounting points up above the rear window filled with a large Phillips screw plug..
My question is the lower mounts, There appear to be a set of center mounts high up under the seat back again filled with Phillips screws. As for the outside mount, there is a big bolt in the floor but it seems a bit too far inboard. What about the bolt that holds the seat-seatback? :?
bam bam
Post by bam bam »
Does anybody have a naked beetle shell that could take some pictures as I have no idea where in the roof to start please ..Thanks
I can. I'll post l;ater
lilbugger
Post by lilbugger »
Here ya go:
Holes
Holes
branston
Post by branston »
lilbugger wrote:Here ya go:
Wow that's my photo of my car! must have come off Samba - but it is there to be shared of course.
Ben
Post by Ben »
I am trying to locate the same holes. The arrows in that picture look to be pointing to where the seat back bolts to. Is that right? There seems to be a bolt the same size as a seat belt bolt that looks like it will work but it is on the floor. Please advise. Thanks.
Ben
branston
Post by branston »
Ben wrote:I am trying to locate the same holes. The arrows in that picture look to be pointing to where the seat back bolts to. Is that right? There seems to be a bolt the same size as a seat belt bolt that looks like it will work but it is on the floor. Please advise. Thanks.
Ben
The seat belt holes and seat back holes are close together. I'm sure I have a photo
Ben
Post by Ben »
Thanks, I am sure it is there. I need to go look again. Carpeting is in place, just need to peel back a little more.
Ben
parafyn
Post by parafyn »
my 66 only has the seat back holes where that arrow points and it doesnt have a seat belt mount hole near it at all. im trying to put seatbelts in mine and i dont know where them outside mounts are
parafyn
Post by parafyn »
i took some pics...
Is that a rusted, broken off bolt below the mount?
parafyn
Post by parafyn »
no, its some dirty foam or something not quite sure the exact material...
I'm doing the rear WW seatbelts now and found this picture helpful.
