I had my '66 body off the frame for a couple of years and taped all wire ends. Upon putting things back together, I want to get it started before I bolt the body back on and am having a problem.
I have attached my wires to the coil in the proper manner with the wire from the key switch on the 15/+ terminal and the wire from the carb / choke on the 1/- terminal and that black wire from ther carb gets hot when I turn on the key and nothing else happens.
If I put that wire on the 15/+ terminial, then the engine tries to turn over but won't start. All my fuses are new but I do have the original wire harness in there.
Any suggestions??
Joe
Syracuse, N.Y.
