Hood trigger switch for car alarm
Teal
Post by Teal »
After many attempts to locate & adjust the shock sensor for my dub I've decided to resort to pin switches to effectively protect my baby. Does anyone have some advice for placement and installation of a hood switch? I could drill a hole anywhere along the perimeter and eventually get it right, but I don't bring drill bits near Lola unless I've got a good plan.
Any help, pictures or advice would be great!
BERHAN
Post by BERHAN »
any thoughts of a mercury switch?
BERHAN
Post by BERHAN »
Teal
Post by Teal »
Great idea!!! I'm on it like pastrami on rye.
BERHAN
Post by BERHAN »
glad to be of service, let me know how it turns out
Teal
Post by Teal »
Slam bam thank you m'aam, I ordered two switches from Amazon. That will take care of my deck lid too, yahoo! And no mounting holes I can stick-em on. Great idea that's why I came to this forum.
I'm going to go with the self-adhesive strip that comes with the units, but that might heat up to questionable temps on the deck lid... has anyone glue-mounted a switch inside the lid? I'll try the adhesive but I might be back, I suspect the AZ sun will weaken it then my cruising speed on the freeway will shake it loose. We'll see.
I guess I'll find a good tie-off point so that one doesn't end up in my belt or even worse bouncing behind me like a geek-a-thon wedding sendoff.
nite!
high temp silicone or epoxy. Nothing else will do. Front one too. Adhesives aren't meant for our summers.
BERHAN
Post by BERHAN »
I have one in my engine bay, haven't had a problem yet, but it better to be safe than sorry
Teal
Post by Teal »
I'm going to follow suit and install one front and rear. Did you mount yours low and a steep degree or higher up at a slighter degree? I guess there aren't too many spots where we part on an incline in the valley, what degree should I set the plane?
I'm digging on the brainstorming, it's sweet pulling a plan together. Thanks for your help!
The Mexican Beetles have these for both the hood and decklid, and they simply install a little bracket and use the regular domelight switches from the doorjambs.
Teal
Post by Teal »
I installed the hood mercury switch last night, works great! As I gather momentum for wiring the stereo I'm going to pull a conductor for the deck lid switch as well.
I love it when a plan comes together!
-Teal
BirdMan66
Post by BirdMan66 »
Good call BERHAN with the mercury switches.
If you're serious about protecting you Bug, try and get set up a pair of those small airhorns from Harbor Freight to replace your siren.
If you're really REALLY serious about protecting it get a fuel cut off.
