generator
Hi Cavs66! This is what I pulled out of the section on replacing the regulator in John Muirs book:
The thin wire in the generator is the field F or DF, the thicker one is the armature + or D+. On the bosch regulator the + terminal is on the right and the F (field) terminal is on the left.On the right side of the regulator there are two connections, one small one and one large one that sometimes has more than one wire connected to it. The small one is for the wire that runs to the red light. The other is the battery connection and its hot - so DONT let it touch metal.
I'm not sure if this will help or not OR if it's misleading not being able to look at the carwhile reading it - however, If this is confusing - I can always take a picture tomorrow and post it here - let me know! John
Your Bosch reg is marked B+ battery DF Field D+gen hot 61 terminal is your idiot light. Right on John! DO NOT GROUND OUT,they cook them little ceramic elements in a hurry. Also make sure the center screw in the cover is secure.I've seen them fibrate off and the cover will short or arc causing to burn out your reg or worse.Mainly 6 volt reg where mounted on gen itself.
Here are acouple of Pictures I took today - I had to get close so you could see the wires so they are not the best quality but they may help. The pictures show the small braided wire with no covering going into the front left terminal, the thick black wire going into the front right terminal. On the side you see the green wire on the going into the terminal that is front (right side of alternator) and the two red cables going into the rear (right side of alternator).
Scruffy - help me out here - have I missed anything?
Remember I have a 6 volt system so that is what the pictures are representing.
- alternator1.jpg (37.98 KiB) Viewed 17681 times
- Alternator3.jpg (37.75 KiB) Viewed 17680 times
- alternator2.jpg (40.74 KiB) Viewed 17680 times
Hi Scruffy: When you bring up the text box to post - you will see a box below the text field with a dark blue border that says "Add an Attachment". Press on the browse button and you can scan your hard drive for a picture to attach. Please make sure it is less than 500 x 500 or it will not load correctly. Hope this helps!
Usually whatever software displays your pictures will have a tool that will allow you to resize - you may need to scout around in the toolbars to find it - otherwise I believe there are some free software programs on the web that you can download to perform this function. Here's a link a link to a great site where you can resize your photos, just page down and browse on the 350 pixel size - that will work great!:
http://www.bigwebpages.com/big/resize.html
and here is an image resizer that Jan tipped me off about. It is free - you download it to your computer and you have it anytime you need it.
http://bluefive.pair.com/pixresizer.htm
- fourcylinder
