Quality two tone paint job on steel rims
I have some pretty nasty looking stock rims that I would like to restore. Any tips on how to do a quality job? Are there masks you can purchase or put together. I'm an amateur when it comes to auto paint, so this will be a challenge. Maybe the best bet is to turn them over to a pro, but I"m guessing it won't be cheap.
really rough!
really rough!
Rims are looking pretty rough.
Found an answer
I found some useful information on a previous post. If anyone has new ideas I'm all ears. Thanks!
I had mine bead blasted and then powder coated black completely, then on the outer rim a light sanding and then painted to the factory color so that they are the two tone stock color. They look great and with the powder coating they should last a long time.
Two tone rims
Thanks John. Yes based on everything I've seen I think powdercoating the rims is the best way to go. I have identified a media blaster in my neck of the woods and another guy that will powder coat for $25/wheel which didn't seem too bad to me.
Did you use the exact stock white, which tends to be a bit on the bluish side? My spare is still in pretty good shape and is two tone with the blue cream color.
Mike
It is actually a very light shade of blue, and you are right it can look almost white but it is the stock color for the rims. $25.00 per rim is a good price on the powder coating! The beauty of the powder coating is that it will last a long time!
Black color
When you powder coated your wheels did you specify the VW black, or just go with a gloss black that the powder coater specd?
I can't really remember anymore, I think I compared the Black to the powder coat (gloss or satin) and picked the closest match.
Well the rims turned out OK. The media blasting left a pretty rough finish for the black powder coating. Here is the method I used to paint the interior rims with L87 Pearl.
Just powder coated, ready for masking.
3M painters tape works well. It took a while but I found this to be the easiest way to mask the rims.
The finishing steps...
A little closer up. It will do for getting around town.
Finished wheel compared to stock rim. Looks OK from a distance
The masked and painted rims
Beautiful!
Ferrety76
Hubcap clip conundrum
Post by Ferrety76 »
I purchased a 1966 a couple of months ago. The wheels do not have clips. How do one install the hubcaps? The wheels have the VW logo and also say 4J x 15. I would like to install hubcaps on my new beetle and I do not really know how to install them with no clips. Help please.. thank you. And by the way rokemester, your wheels came out very nice!
russ c
Post by russ c »
if there the orig 66 slotted rims they dont have clips.they use the flat hubcaps
