The Pan is remarkably good shape
Some rust under the battery box but only surface
The doors began in very good shape, but I want to replace all rubber and window guides
I used a valve clamp to remove the pins on the door and window latches becasue I ran out of hands
The original plastic is still on the inside of the door
Yes this is the other side, but they look the same.
All I have left is the gas tank removal, and the engine and I am headed to paint.
