Pros and cons of the '66 Beetle.
First of all, there are not many cons.
I always thought the smaller windows on the earlier Beetles looked better (and still do), but that's from outside the car, not inside. From a driver's standpoint, it's much nicer with the big windows. VW did a good job reducing the cave-like aspect of the car by improving the visibility, while making the car look more modern.
The one thing I don't like about the larger windows is the flat sill under the door windows. Water sits on this sill and rusts it out, something the earlier doors never did.
Other great features include the stainless steel door and hood handles instead of chromed pot metal. That was a real classy use of materials for Volkswagen at that time. I also like the improved headlight switch, which can be retrofitted to earlier models. If you want to upgrade your older car's electrics, put in a '66 headlight switch.
I also like the small '66isms, like the dimmer switch in the turn signal stalk and central defroster vent. If your heater is in good shape, that vent really makes a difference. Such a simple solution, you wonder why they didn't think of it sooner.
And one thing my car was missing was the distinctive flasher switch on the dash. It took some looking, but I eventually found a stash of them, including some NOS screw-in faces with perfect paint.
I know these distinctions are mentioned elsewhere on the site, but I thought I'd mention them again, because it's part of what makes a '66 a '66.
My only other complaint is the 4.37:1 transmission with the 1300 engine. It could have used some longer legs to take advantage of the improved torque.
6V electrics are a big con in my book. Yes, properly maintained your lights can be just as bright as a 12v system, but finding replacement parts is becoming increasingly difficult, and if you want to add any kind of modern conveniences (a GPS, for example), you have to have some way to power that 12v circuit.
Other than that, I more or less love my '66
I sat and read through lots of books and decided a '66 was what I wanted before I bought a Beetle. It has the most upto date improvements, before the cars lost their sloping headlights.
It drove my family mad though when we were having trouble finding a good one. They kept asking if I would be more flexible on the year, as it was narrowing the search considerably, and I was always, no!
- rokemester
What's to love about 66
The classic bumpers and the beautiful headlights with the cool parking lights embedded into the light compartment. Nothing cooler than running around town with parking lights only just before dusk. The car looks so sweet!!
66 Flasher Switch
The 66 Flasher Switch (looks like a red bullet) is certainly becoming scarce. I bought a good piece in Oct 2007 for $50. Now prices fluctuates from $30 to $150 ? Yes saw one in Samba advertised by someone in Canada for this price.Ferdykid wrote:I spent some time looking out for a flasher switch too - mine is a rhd uk spec, so didn't have one fitted as factory - just wondering what the best position for it would be. Any ideas?
You may still find one at a resonable price. Whatever, do not substitute this switch with another type. This is IT.
Re: 66 Flasher Switch
I managed to get hold of the correct one for a good price in Decemberlarryho wrote:The 66 Flasher Switch (looks like a red bullet) is certainly becoming scarce. I bought a good piece in Oct 2007 for $50. Now prices fluctuates from $30 to $150 ? Yes saw one in Samba advertised by someone in Canada for this price.Ferdykid wrote:I spent some time looking out for a flasher switch too - mine is a rhd uk spec, so didn't have one fitted as factory - just wondering what the best position for it would be. Any ideas?Asked him and he confirmed that the price is correct.
From the pics I have seen, below the left corner of the radio plate is the absolute correct place but 1) it should be slight recessed like the headlight and wiper switches, which wouldn't be easily done and 2) it doesn't look nicely symmetrical, just like vw were told to add one anywhere - almost would be better between the two existing switches! It's a big decision to cut an uncut dash!
Maybe I'll do some photoshopping to see what would be best - get a vote going! watch this space!
An Optima battery goes a long way toward improving the 6-volt electrics. The '66 VW already has the improved style of headlight switch.
One little trick you can do to improve the 6-volt system is to replace the bolt that holds the battery ground strap to the pan with a longer one, and then bolt another cable from the pan bolt to the lower starter bolt on the transmission. This will improve the ground big time.
