parking light bulb contact
bajadave66
Post by bajadave66 »
Just noticed that one of my parking light didn't work. After taking apart the light assembly and checking for Voltage and the bulb which was all good. I tried to make the bulb spring clip have a better surface contact and while doing that, I broke the little parking light contact clip. Where can I find a new part so i can replace it. It is held on by 1 small screw. I've check several shop but no go!
Check out Wolfsburgwest, worse case scenario you can get the whole light assembly there if you need to.
bajadave66
Yeah, I bought the whole assembly plus one more. I had to match!!
