Gearbox Rebuild
Gearbox Rebuild
Yesterday was one of the worst experiences ever....that had several lessons. Poor pressure plate diaphram jacked off position....and after replacing, found the gearbox got stuck on gear 2 and would not budge NO MATTER WHAT!!
I think I want to attempt a gearbox rebuild. I need all the help on this. It feels like a surgery proceedure that is so delicate with a wrong move rendering me in a future sorry state.....or is it not????
Old post.....
Kindly send me the link. Thanks.
Sorry, I misread your post. A gear box rebuild is not something to take lightly. You need specialized tools (some you can make) and fixtures for assembly and it is not something easily explainable in test messages. Look at the video on YouTube Building a VW transmission and read al bunch before you start.
Thanks Darzoom.
I have a vw service manual I will try follow to the later and all YouTube resources.
Thanks for that note.
Sometimes you can jam the transmission in two gears, and you can remove the transmission nosecone and move the shift forks around to unjam them.
Forget rebuilding the transmission yourself. It takes numerous special tools and you must be an experienced rebuilder who is in practice.
In a similar vein. I've asked this question numerous times and never really got a 'straight' answer: is there anyway to 'diagnosis' a transmission for potential issues while it is not attached to an engine? The tranny in my 66 jumps out of 2nd gear. I have two other possible 66 swap-in gearboxes, but not sure of their condition ....I'd like to have a general idea of their condition before I do all the swap work. Any suggestions???
Blue Baron wrote:Sometimes you can jam the transmission in two gears, and you can remove the transmission nosecone and move the shift forks around to unjam them.
Wow!
I just wish the first suggestion will work for me.
Cheers.
All you can really do with the transmission out of the car is turn the axles back and forth against each other to look for excessive wear in the ring and pinion. You can also drain the gear oil to see if it's clear, or if it is a mess of metal shavings. As to whether the tranny is any good, it's basically a crap shoot.
