Throwout Bearing Help
66_Bug
Post by 66_Bug »
when changing flywheel, clutch and pressure plate from 180mm to 200mm is the throw bearing the same or is it different for the larger clutch? Thank you![/img]
....to whoever has the answer, please, if with a difference, post a pic of the two.
