1972 Bus Brakes Master Cylinder
Hi Guys.
Im working on a bus and noticed its brakes master cylinder is missing. Would a 1967's bug brake master cylinder surfice the deficit?
daves66
Re: 1972 Bus Brakes Master Cylinder
Post by daves66 »
KKV270 wrote:Hi Guys.
I really doubt it is right, likely the Bus needs a different volume of fluid delivered than the Bug to move the pads to contact the drum/rotor (did the 72 bus have front discs???) The Bug had tiny wheel cylinder's relative to what I bet the Bus has, thus the bus should require a larger master.
The bore diameter and stroke may not work, and the outlets for the metal brake lines may be in different locations, requiring a lot of work to get the existing lines to fit, if they can be fit.
The bore diameter will determine how much pressure can be built up in the brakes with a given foot pressure.
I really don't know, but I doubt very much it is a good choice. the Bus has such a different brake need, it is near twice the weight vehicle after all.
No, a bus uses a power assist.
