Rewire
Wiring a 66 Beetle
It depends on whether or not you are going back to the stock 6 Volt system or customizing it into a 12 Volt Resto-Mod. You'll need to use
the heavier gauge 6 volt wiring if you stay stock, especially on the battery cables. I think you can get most of it in a harness from VW parts suppliers.
66 VW wiring
I've wired many of my own restorations (other than VW) and recently helped a friend who had a kit. Never again will I do it from scratch.
Reason: I knew what each wire did, but the person who cam after me never could know. Therefore a standardized wiring is my new preference. Because I've kept some of my cars over 25 years and memory can fade, I think wiring that matches the available repair books is to my advantage too.
