Hi,
I'm doing an original restoration on my 66' Bug. Running the 1300cc and 30PICT1 carb.
There is currently a 009 distributor on it. I have a 205 (vacuum adv) that was given to me.
Which distributor did the 66' 1300cc come stock with from Germany?
which vacuum adv dist is bet for the 30PICT/1300cc?
Steve
Distributor for my 66'
I'm no expert, but found this.......
http://www.oldvolkshome.com/ignition.htm#A6667
Beetle 1966-1967 * 1300/1500
Distributor: VW 113-905-205K/L, Bosch 0231 137 009/010 > 315-905-205B, 0231 137 031
Can Use: VW 113-905-205M, Bosch 0231 137 021, 113-905-205T, 0231 137 035 or 036
Points Replacement Plate Assy: VW 111-905-227B, Bosch 1237 110 139
(Note: Order 01 013 Points when using this Plate Assy)
Condensor: 02 007 - Note: If equipped w/AC use 02 069
Rotor: 04 006
Cap: 03 001
Parts Kit (Shims, Washers & Hardware): 059-998-211, Bosch 1237 010 007
Coil: 6 Volt - 00 001, 12 Volt - 00 015
Blue Coil: 6 Volt - 00 016, 12 Volt - 00 012
Vacuum Can: 07 017
Ignition Wires: 09 001
Spark Plug: W8AC
Timing Set At:: 7.5deg BTDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum (Advance Only): 17-19deg @ 1.3 In. Hg, 24-28deg @ 3.2 In. Hg
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 017
Spark Plug: W8AC
