A buddy of mine was moving, and could not take his 1966 Type I with him. A deal to sell it on CraigsList fell through last minute, and he asked me to buy it. More as a favor to him than me wanting the car, I purhcased it for $800.00. I've never owned, nor thought I would own, a Volkswagen. Oh well, it looked like fun.
I had to dolly it home, a distance of about 75miles. That was mid July. So far I have gotten the following done:
Re-built generator
New stock voltage regulator
New fuel tank, fuel lines, fuel pump
New stock carb (long battle with that one, 12V vs 6V learning curve)
New floor pans
New stock steering wheel
New stock turn signal assy
New odometer (not installed yet)
New speedometer cable (not installed yet)
New EMPI wheels (not installed yet)
New headlights
New license plate light
New 6V grounding wire
Repaired boot lock
New weather stripping (temp measure, cheap rubber-- will redo when I paint)
New door lock key (vehicle did not have one at time of purchase)
Here's a picture:
I've also stripped the interior, and am running with just the driver's seat. I purchased a set of used (in good condition) 1966 lowback seats. I re-upholstered one of the old seats so I could drive it.
I plan to paint the car a dark metalic green, and install a simple black interiror from Sew Fine. The 1300cc motor will be stored, and a new "Turn-key" motor (+transaxle and rear axle) installed.
So far I've found very little rust (except for the pans, which have since been replaced)
The tires were bad when I bought it, with side cracks from the weather. I put off buying new tires because I hadn't picked out wheels yet. I hadn't picked out wheels because I wanted to do the brakes first. A good plan, until I had the driver's side front tire blow out on the freeway.
I got the new wheels this week, but I'm waiting for payday for new tires. I had Big-O order one each of two brands, Yokohama and Nitto. I forgot the size, but they are wider and shorter than stock, but should not interfere with anything. I will pick one out Monday afternoon and plan to install them Friday.
Once I reach this point, I will have a reliable driver that I will feel comfortable with as I shop for other parts of this project.
As I get things done, I will add more pictures.
