Hi Matt! Actually from what I can see in the pictures she looks pretty solid. Some of the folks in the forum are experienced in restorations so they should be able to answer questions for you. Best of Luck with the restoration.
Looks like one outer, though tough to tell with the fenders off. They're pretty easy to re-index. You should get yourself an angle finder at your local hardware store, that's really the only way to set the spring plates correctly.
