hey all, So I've been reading through similar forums related to starting problems and I'm not sure if I have the same issue. My motor is a from a 68, its 12v, and I can't get any spark. It just decided not to start on me one day. I tried push starting it and nothing. So I figured it was an electrical problem(s). Problem one is a wiring disconnect to the coil. that one's easy, so I bypassed that to make sure that the coil was getting electricity and still no spark. I checked to see if the coil was making sparks and it was. So I removed a spark plug to see if it would spark when connected to the distributor lines and the engine turned over, and nothing. I'm assuming that that means its a distributor problem? any help is greatly appreciated, along with wiring diagrams. I want to make sure that the wiring is right. Thanks all
It was running when i took the pic.
