what color white is that on the 66 rim
russ c
Post by russ c »
want to restore my rims does krylon or rustoleum have a color to match the white part ofmy rim regards russ
Rubin66
Post by Rubin66 »
According to some opinions, Krylon Almond is a close match to the most common wheel paint color, which is L87 Pearl white.
Check here for more info and color matches...
http://www.thesamba.com/vw/forum/viewto ... ylon+paint
If you have a Sea blue or Bahama Blue Beetle, the wheel color should be L289 Blue-White, I see no match listed.
Some samples here...
http://www.thesamba.com/vw/archives/inf ... stype1.php
russ c
Post by russ c »
thanks rubin
branston
Post by branston »
And if you want a paint code to get it mixed by a paint supplier and use a spay gun. I have the right color codes. PM me
smccoy
Krylon Almond
Post by smccoy »
I've had real good luck with Krylon's "Almond" paint, as well- it's just the slightest bit brighter than my original paint- but it's great for hidden interior touch ups or wheel rims that have some distance between them and original panels. Wouldn't try blending it into anything original or big and visible like a fender, but it's not bad- and fairly inexpensive and durable, too.
