shift rod bushing
shift rod bushing
How does this bushing go on the shift rod and ,should it be inserted into the hanger?
Re: shift rod bushing
Yes it needs to be put into the hanger with the metal ring too. Put it in place and them slide the shift rod into place with a touch of grease. get a helper to guide the end of the shaft if you can. I was dreading this job and it took 10 mins to domt1966 wrote:How does this bushing go on the shift rod and ,should it be inserted into the hanger?
