One of my brother club members from the Ventura CA area hand delivered me a set of 40mm Kadrons yesterday for Clyde (6+ hours to Phx) . I slapped them on last night, got the car put back together to the point where it would fire and idle(poorly), and then decided to tune this morning. I'm running a 1641 that is almost bone stick, just an 009 and a generic empi small flange 3 bolt header and baffled stinger.
10 minutes of idle and mix tweaking, a little water on the street at 9 am this morning and a nice burnout into third gear.
This is my first experience with dual carbs. I was expecting the usual headaches of tuning and synching, but it literally took me 10 minutes to dial them in. The balance tubes on the manifolds for Kadrons make all the difference.
If you want to play around with something that will bolt in over the course of an afternoon and completely change the way you drive, I'd highly suggest picking yourself up a set. Try and find some nice older ones at a swap meet and rebuild them, I've heard the newer empi ones aren't as reliable as the OG kads and the early brosols. You can find them in good shape in the 3-400 dollar range, and anything under 250 is a steal.
