Start problem
ljmlaw
Start problem
Post by ljmlaw »
Having issue where my car won't start. Starter is good. When I turn on the ignition I lose all power. 6 volts until I turn the ignition then nothing. Any ideas.
Get an answer?
Check the large wire on the light switch. If loose you will have this as an issue.
hercdriver
Post by hercdriver »
How old is your battery? It's starting to get cold. If the battery is weak, the colder weather will only make it worse.
