Condensor-Coil connection
Was doing some wiring and got a little bit confused. Could someon kindly confirm to me where the green condensor cable to the coil goes?? +ve terminal or -ve terminal?
What would the repercussions be if inversed?
hercdriver
Post by hercdriver »
Here's a wiring diagram from 66.
and the key....
Hercdrive,
A big THANK YOU!. What I did (now I realize), I disconnected the automatic choke cable that comes from the coil for lack of info on what it is as the manual I have only indicates the ignition cable to the coil. Glad to confirm the cable colour code (what I disconnected) is the same as what is on the choke.
I truely appreciate.
hercdriver
Glad to help. A picture is worth a thousand words. :D
