Happy new year to you all!
I will be greatful, if any one can help to fix the spray system of water for wiper. I saw a water reservioier connecterd with the spray having an air value like an inner tube valve. I am still confused how to make it work.
Thanks
water spray for wiper
Happy New Year to you too endashaw!!!
When these were used, there was a line that went from the spare tire to the water tank (that is air valve you are mentioning in your post), then a line from the water tube went up and connected behind the wiper switch. You may want to be very careful if you decide to use your spray system as many leaked down on to the radio and caused issues when they got older. I do not use mine just for that reason (I don't want to take the chance).
