Hi there,
i have an original vw distributer, the engine runs great but after a really long journey (300 miles) i had to re-set the points gap on the distributor because it wouldn't start.
Does anyone have any thoughts on whether or not i should change ny distributor and get an electronic ignition kit?
Leane
? electronic ignition - any thoughts?
- engine.jpg (48.07 KiB) Viewed 4061 times
sound like your distributor shaft or bearings may be worn where the dist cam walks from one side to the other or your points may be getting hot to change your point gap.either way electronics should do the trick.
