Front End Assembly
Front End Assembly
Would a front end assembly including steering gear box from a 1973 bug fit on a 1966 bug with no modifications?
Lots of changes for Federal safety regs in between there. In general, I think it should all fit, provided it's a 1973 standard and not a super beetle. If it's a super, everything is completely different. You'll probably want to use your earlier steering column and whatnot and make sure that everything measures up correctly.
