Super m's 66 build
Here's the spot to show off your 1966 Beetle Restoration projects
SUPER M
Super m's 66 build
Post by SUPER M »
I have a lot of pics .... hereare some with the body on the rotisserie..
SUPER M
Post by SUPER M »
Here is the pan....
Before..
After....
I had to repair the front sheet metal and the pans.....
Undercoated the bottom....
POR'ed the top...
Very cool - really nice work!
SUPER M
Post by SUPER M »
Thanks ...... John 8) Here is the transmission
Before...
After....
And the transmission on the pan...
SUPER M
Post by SUPER M »
I also narrowed the front beam 4 "......
Cut the shock towers off....
Cleaned up the ends...
Cut the beem at the center....
Added the adjusters....the one on the left are the ones I used...
And welded on the end plates....
Cleaned up the welds..
The finished beam....
Check out the size difference...
On the test pan to weld the beam up ....
SUPER M
Post by SUPER M »
And here's the steering box....
Before....
After.....
SUPER M
Post by SUPER M »
And the winsheld wiper assembly....
Before.....
After....
pachizeron
Post by pachizeron »
It's a real cool project my friend. Great job.
Looks like it will be brand new when completed - really nice work!
SUPER M
Post by SUPER M »
Thanks guys I still have some more on the body to fix . This poor car looked to be in good shape but a closer inspection it was in sad shape it was a gift so i have to bring it back but with a little twist....
Super m
SUPER M
Post by SUPER M »
Home made peddle pads. I started with raw alum.
My pattern.
Cut out the blanks
drilled out the pads.
The finished pads..
SUPER M
Post by SUPER M »
Refreshed the alternator...
Before...
After....
SUPER M
Post by SUPER M »
Also cleaned up the speedo....
SUPER M
Post by SUPER M »
Diamond plate inspection cover hand made..
SUPER M
Post by SUPER M »
I also drilled holes in the emergency brake handle.
