Hi y’all, my OG 6 Volt 1200cc VW beetle red light stays on all the time. How do I check to see if the Voltage Regular is working properly and or if the Generator is working? How do I check to see if the 6 Volt battery is charging?
Thanks and look forward to the replies
Jeff
66’ red generator light
Re: 66’ red generator light
This might move you in the right direction:
http://www.vw-resource.com/warning_lights.html
Also, please post technical questions in the technical section, most folks won’t come to the general chat area. I’ll move this post over there shortly. There are some knowledgeable people on the forum that should be able to help as well as some previous posts (more than likely)
